Late last season my holding tank seal broke. When looked into it it appeared that the air vent was clogged since I noticed a huge bubble in the on the lid of the holding tank. After pumping out the tank and clearing out the vent line (nothing was in it) the tank again swelled and sprung new leaks around the seal and still could not figure why. I began to try to open the lid but will not be able to without distroying the lid. My questions are:1- Can I get a replacement lid from Hunter ('88 28.5). Should I replace it with something different.2- Do you have any idea what may be the problem assuming that there is nothing clogging up the air vent. 3- Do you have any advise in getting into the holding tank since the seal is broken. I has tons of (I assume) 3M 5000 sealer.
