Thinking about installing a bowsprit on my H36 this winter (unfortunately not far off here in Chicago). Has anyone had experience doing this project on an H35.5/H36?
Thanks chuckwayne. That's good info! Was wondering if that was an option to use the anchor roller.Ken, you should be looking at the 356, not the 35.5.. The problem we both have is that to support the sprit it has to be mounted across the anchor locker. Selden and forespar both make kits for a removable sprit that will work, but you have to remove and stow it for anchoring. I've looked at the installs, but I fly my chute from a block (for the guy) on the forward end of the anchor roller and it works great - the sprit kits only gain you about 1-1 1/2 ft more extension, and I'm not sure it's worth it
