G
Gary Scheier
We have a 1991 Hunter 28 with a Jabsco #29090-0000 MSD. It probably needs rebuilding since 1)I think it is the orginal, and 2) the holding tank is leaking back into the bowl, and 3) we are getting "spray" out the top of the pump onto the engine compartment. BTW, the tank is in the hull bottom under the swim ladder (lower than the head), so I am a little suspicious of the outside vent being plugged.In a previous article, you recommended the Raritan Cricket head. Would this be advisable, or just rebuild the old head? How old is too old? West Marine sells the rebuild kits for about $45. Also, it appears that the Cricket is only a little higher than the existing head, but the other dimensions are similar.GaryS/V Serenisea
