Boweye Backing Block
Ranzo
May 11, 2022
18
Catalina 22 3556 Farragut, TN
Hello everyone! I was installing the Catalina Direct boweye kit and did a poor of drilling the upper hole. Is it worth an epoxy fill and re-drill attempt, or will it matter much as it is? Thank you!
Sep 24, 2018
3,630
Catalina 30 MKIII Chicago
is it just the block that's misdrilled or the fiberglass? if it's the latter, I'd run to the hardware store for for some Unistrut washers. They're very thick and have a heavy anti corrosion treatment. They'll outlast the boat in freshwater
Likes: Ranzo
AaronD
Aug 10, 2014
746
Catalina 22 9874 Newberg, OR / Olympia, WA
1) The CD backing block is made of High Density Polyethylene. Most epoxies don't really adhere to HDPE (and for those that will bond, flame-treatment is sometimes necessary). So if I was really worried about it, I think I'd skip trying epoxy and instead buy another $10 block and drill again. That said...
2) The block is there to stabilize the bow eye ad distribute the load over a few square inches of fiberglass. If it were my boat, I wouldn't be concerned that the overdrilled hole might cause the block to pull through the bow.
I tend to be overly paranoid about all my repairs; and in this case, even I am definitely in the camp of, "Bolt it back together and go sailing."
Sep 24, 2018
3,630
I meant to say use some heavy washers if it's just the plastic block. If it's the fiberglass, you might want to fill it back in and redrill
