bow thrusters on Hunter 46
joyce
Where is the circuit breaker for the factory installed bow thrusters on the 2006 46?
It is not on the dedicated panel with the rest of the large system circuit breakers (I do not mean the AC / DC panel with light, pumps, etc switches).
NYSail
Jan 6, 2006
3,146
Beneteau 423 Mt. Sinai, NY
look where the thuster is installed....thats where mine is.
Good Luck
Greg
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Hunter owners
If you post this up on Hunter owners, you will probably get much better and more knowledgable response.
Jun 4, 2004
292
Hunter 49 123
Check Pages 63A-7, 63J and 64L-1 of your ownwers manual. I dont have page 43J but can send you the other 2 pages if you send me a PM. I think that the breaker is in the same location as the battery switches (63A-7). I hope this helps. V49
joyce
thanks velero, but ...
The owners' manual for the 46LE was never updated by hunter to show the changes from the 466 in the layout below. The nav areas on the two versions are different and the panel locations are moved, so my manual doesn't help.
