Bow Thruster
127
Beneteau 36 cc Humlebæk
The bow thrusther - a Lewmar 12v 3 kW - in our Oceanis 36 cc stops after 3-5 .
The volatage on the is ok.
Has anybody got an idea of what can be wrong ?
Beneteau 323 Annapolis MD
When I run my high-draw windlass, I have the engine running and all three batteries (including the start battery) on line to minimized draw-down. I assume there is a relay which makes you have the engine running in order to operate the thruster?
Mike B
Apr 15, 2007
1,013
Beneteau 43 Baltimore, MD
Some thrusters have thermal fuses. If yours has one it's possible it's cutting out on you prematurely. If you do not gave a thermal fuse check for loose, dirty, poor connections. It's possible you have one that opens once it gets hot. I'd do voltage checks both prior to and while running the thruster.
Apr 27, 2010
968
Beneteau 352 Hull #276 Ontario
You could put an amp meter in series with the battery and monitor.
If you're drawing more current than normal, it's probably that the motor is over heating and opening the thermal fuse.
I also read somewhere that bow thrusters shouldn't be powered any longer than 5 sec at a time.
Oct 2, 2010
127
Thank you very much for the replies.
I am afraid the sad solution is to replace the motor on the bow thruster.
Anyone with experience in this ?
Oct 2, 2010
127
I have now solved the problem. A couple of findings that may be of interest to others.
1. Practising sailing the boat WITH OUT the thruster is a good idea. It is easier than you think and fun too.
2. Make sure the propeller run smoothly in the tube. Antlfoul it if necessary.
3. Uninstall the motor and find someone who can repair it
