How about a water pump with flush nozzles? You could control it with ball valves, or, run dual pumps with simple on off switch/switches marked port/stbd/both. A guy could also put through hulls at each hull opening, so they are closed when off boat, just in case.
Two, 1 HP 120V AC standard hot tub jet pumps could be powered from an inverter off your battery bank. Each pump would draw about 35 amps from the batteries, and should provide more thrust, or at least as much thrust as most trolling motors which are approx 1/2 hp or less. The difference being a trolling motor is more efficient as they use a prop directly in the water. The pumps would kill a battery pretty quick, but as its only intermittent it shouldn't be a large drain. I would want momentary switches you have to hold in to power the pump, which would stop as soon as you release the switch.
