I'll take it that if you're researching bow thruster it's because you've tried other alternatives and determined that it could help your situation. As Bob Mack indicated, the B37, like many modern boats, has a high freeboard which can make it difficult in some situations.
In mine for example, I have a slip up-current on the Columbia river; i.e. current is on average 2 to 3 knots pushing into the slip. So I have two options, bow-in which gives the best directional control, but makes for scarry landing as getting control means coming in with speed over water! This got too scarry for everyone, my neighboor as well as myself and my crew, even with the strong reverse of the B37. The other option is stern in; the advantage is that if something goes wrong you have control pulling back out forward against the currrent. Still, getting control backing in means you have to have speed over the water, and therefore backing in the slip at 3+ knots is somewhat unnerving. I currently moor stern in.
So, regardless of what all well intentioned people say, there are situations where a bow thruster would be useful. One yard I checked with indicated they could mount one in the space foward of the forward tank as long as we limited the diameter to 4". Another aspect that could help is to mount a 4D or 8D battery in the same compartment for both the bow thruster and the windlass. This has two advantages. First, if your boat is not loaded., this ensures the bow doesn't sit too high, which the B37 can often do if you have a full fuel tank and aft water tank. Second, it limits the voltage loss when pulling up anchor.
I haven't done it yet as the thruster installed is about $10k, with the battery, charger etc. extra. But I'm seriously considering it as I would then be able to take the boat out by myself, therefore sailing more often. For now, I have to have a crew for docking.
And don't let anyone tell you you're less than a sailor because of your bow thruster! I would rather see a well prepared sailor using all the tools available than a purist bashing into my boat because the current got the upper hand.
