H31 bow roller
I'm not sure if this will relate to the H28 but it worked great for the H31. I couldn’t figure out a good way to use mechanical fasteners so I had to weld it. The welder got the heat too high and the weld zones are prone to surface rust, you can see I’ve had to paint the welds. The interior SS surface also started showing some rust from anchor chain abrasion so I painted that area too. I have a lot of pics of the set-up. I can only put 1 here. I'll try to post the rest in an article / upgrade format for the H31 section of HOW in the next few days. With a 45 CQR, 120’ of 3/8”chain & 280’ of ¾” triple braid nylon line I can get a good scope even in 40’ of water and I’ve held tight in 75mhp winds.good luckKurt
