Bow roller for the anchor
Thanks Kim. I had mixed emotions when I first installed it, because I wasn't sure whether my Danforth anchor was going to clear my bow when I raised it, but it does. Also as I pointed out, some rollers have a bail to keep the line from slipping off the roller. A lot of times as I'm pulling my anchor line up, sometimes the bow of the boat will ride up on the anchor line so that I'm pulling at too much of an acute angle, where having the line attached to the roller makes it hard to pull, and it's a lot easier at this point to pull the line against my bow rail until the anchor line is more centered with the roller. Then it's just a matter of putting the line back on the roller and hoisting her all the way up. I've only had two occasions where I had to use the snatch blocks at the bottom of two of my stanchion rails to be able to lift my anchor from the cockpit, and operate my outboard at the same time. This anchor roller set up is very common on some sailboats. I've tried everything, and I've found this to be the best for me because it's very easy on my back. If you have a problem trying to break the anchor out the mud, just pull as much slack out of it as you can until the anchor line is almost vertical. Then cleat it off temporarily and wait a couple of minutes. It'll pull out. I really enjoy pulling up to a spot under sail and dropping my anchor. When I get ready to hoist my anchor, I have my main sail hoisted and ready to sail off as soon as I get the anchor stowed on the roller. I've also learned through experience, that it's always a good idea to raise the centerboard before anchoring under sail. There's nothing more embarrassing than having your anchor line caught on your centerboard. I think that we all learn through our own mistakes. Believe me, I've been through the school of hard knocks, and I'm still learning,-- all the time. Good luck!
