bottom paint
144
Hunter 22 Kingston, Wa
How important is antifouling bottom paint on a boat that is trailered and never left in the water for extended periods of time?
Rick D
Jun 14, 2008
7,192
None Needed
You begin to accumulate some slime after a week, but otherwise, not needed. Most dry-sailed race boats do not have bottom paint (in SoCal). RD
Dan
2 days max
After 2 days in the salt water you will get barnalces about the size of gains of sand. If you do not scrub them off, your in for a big job.
Aug 9, 2004
144
thanks
Since all I do is saltwater, and I want to spend several weekends on the hook this season, I'll just have to repaint the bottom with antifouling when I do it. Hopefully that will be a project for next year or this fall.
May 23, 2004
117
Catalina 30 Stockton, CA
Paint for Trailering
Make sure that the paint you put on is suitable for trailering. Some paints are too soft and not suited for trailer boats.
Aug 9, 2004
144
specifics
Bob, can you be more specific in what to look for in a "trailerable" paint?
Drew
Trailer Paint
K/P: Ablative paints are considered "soft." They excrete biocides to keep growth off your (boat's) bottom. Don't use it on a trailerable - the bunks will wipe it off everytime you go in and out of the water. I use Interlux "Fiberglass Bottomkote." $100 bucks a gallon good and hard. It works great and lasts two years with a little touch up on the off year. And I keep the boat in the water all summer - fresh to brackish water. My only caution is that you consider what appears to be your saltwater situation and ask the local chandlery for advice. Good luck. Drew
