VC-17
Dan, I think VC-17 is also manufactured by Interlux, and is considered a 'co-polymer ablative' paint. What makes VC-17 different from other co-polymer paints is that VC-17 has Teflon in its mix, and a MUCH smaller percentage of the anti-fouling agent ('biocide') in it-- Half as much as CSC Micron, if memory serves correctly. I don't remember if VC can be applied over Bottom-Cote or not. I agree with Charlie and Dakota Jim, you could contact West Marine, or check out the section on bottom paint in their catalog. You could also contact Interlux- they have a web page at http://www.interlux.com , and there should be contact info on that page... Some other comments about VC-17- It's not sold by the gallon, like most other bottom paints... It takes 5 cans of VC-17 to get a gallon of paint. Once you figure out the coverage area, it costs about the same to paint with VC-17 as it does with CSC Micron (extra? Plus? I can't remember the 'new' designator for CSC...). I'm planning on using the VC-17 because my boat lives on a trailer most of the time, and I think the teflon will help the bottom paint stand up to the abuses of trailering. If you leave the boat in the water, especially in salt water, you may want to consider another paint.--Jon BastienH23 '2 Sheets to the Wind'Key West, FL
