This is a job that would typically be done in the yard.If it needs to be sanded occasionally to expose fresh biocide, you will run "afoul" the EPA of the Peoples Republic of Maryland.
A friend of mine with a C41 is spending a fortune to have a diver veeeeeeery roughly remove the fouling and sand where he can to reactivate the copper. Hauled it once to power wash and sand at even greater cost.Has anyone had any experience with CopperCoat - supposed to be a ten year paint?
WOW, 8 years?!! I've used the WM, Pettit, and Micron ablatives and the second year I get growth. Either I live in a really bad area or you live in a great area or both.The year after we purchased our 1991 P42 in 2002 I hauled the boat and painted the bottom myself. I applied West Marine brand ablative using a paint roller. That paint job lasted until 2010 when I did the same thing again using the same brand of ablative.
Nope. Anti fouling paints simply do not deliver their biocide for that long. It may be that a boat bottom isn't fouling much after 8 years, but its because the fouling conditions are practically nil, not because the paint is still doing its job.If you check where shelter bay is, it might make more sense, depending on the tides, and how far back the boat is in the pond, the layer of fresher water on the surface can vary 1 to 3 ft. with very low CO/Oxygen in the water. 8 years is a bit long, But if the boat is not putting on hundreds of sailing miles a year it is possible. however 5-6 is pretty common. Even in Edmonds (straight saltwater) we get 4 years pretty easily with the cooler water with high solids paint.
YMMV
1.- Not all anti fouling paints are ablatives.Not to go all engineer here.
Parameters
still water, low 02/ low C02, very little wind,low temp, boats rarely move. all affect the ablation rate.
And what is the water temp today????and July?? I have broken ice while sailing in May! May 3 Stockton IslandI get six years on Lake Superior...............Carry on.
