bottom paint stripping
mike campbell
any recomendations on stripping the bottom? dry ice, walnut shells, sand blasting or good old sanding? thanks Mike
John
Yes
Yes I sand blasted our bottom. Then epoxy, then bottom pain
Rob Morton
Soda Blasting
Is there a place that does soda blasting? It takes stuff off like sand blasting but is not a harsh. It seems to work really well. Rob Morton
Bob
Don't sand blast!
Mike, Accoding to Don Casey's book "This Old Boat" - ...."fiberglass hulls should NEVER be sandblasted. Sandblasting destroys the integrity of the gelcoat, making it pourous and almost certianly leading to hull blisters." He says that the safest way to prepare a hull is to scrape it with a hook scraper. See his book for all the details. I used his method and it worked well for me and was a lot cheaper and easier then sanding the hull.
