Bottom paint question
Apr 13, 2015
157
Catalina 309 Port Charlotte
Hey folks - looking at probably hauling and painting the bottom on my 2007 Catalina 309 over the winter (even though that is some of the best sailing times down here in FL west coast). This would be the first time I do this. Can anyone tell me how much paint they've used in the past for a coat? (would be similar to a 310 or even a 30). Also what brand of paint you used and your experience?
Only had the boat since last spring, one thing I don't know is if the bellows has ever been replaced on the PSS shaft. If replacing that, does the rudder have to come off to get the shaft out?
Any info is most appreciated...thanks - Dave - Tampa, FL
May 12, 2004
1,505
Dave, I'm here in Tarpon Springs and have been using Seahawk ablative for years with very good results. It's made here in Clearwater, I believe. If you use your boat frequently, ablative is the way to go, IMO. I can get up to about seven years between bottom jobs. No more scrubbing the bottom. In the summer when the water's warm, I run up in shallow water and and check the bottom and zincs. Maybe a few barnacles from time to time and scrub, lightly, the waterline but that's it. My h30 takes two gallons. Two coats on the bottom and three at the waterline. Also have a dripless PSS but haven't had to replace it yet. I'm hoping that when the time comes I don't have to remove the shaft.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
The general rule of thumb for figuring bottom paint is:
LWL x max beam x.85. This will get you pretty close depending on paint type used and the method of application. It was quite accurate for my H28.5 using a 1/4" roller applying Petit Hydrocoat Ablative.
Sep 23, 2009
1,475
The first time we did our 34 with two coats we used 1 1/2 gallons Pettit Hydrocoat. Last year we used close to one to do one very heavy coat. It is very easy clean up and has kept growth to zero. Of course our waters are very different from yours and our season is shorter.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
How much room do you have to slide the shaft with prop before hitting the rudder,don't need alot of room to slip pss bellows off and on.
I just changed my bellows on my 07 and it was still great shape and could have gone longer.
Mar 20, 2007
500
Catalina 355 Kilmarnock, VA
You will need to drop the rudder to remove the prop shaft on the C309. The shaft seal bellows can be replaced without removing the shaft; problem is that the shaft flange will need to be removed, which is an adventure in itself, and likely replaced with a new one; this requires machining the face of the new flange while it is installed on the shaft, which obviously requires shaft removal. I did this job on my 309 several years ago before I sold it; there should be a write up somewhere in the archives.
Warren, is that to gallons?
Apr 13, 2015
157
Stu, I think his formula must work out to square feet...as mine would be 250+ gallons!
Then you use your paint's expected yield.
JSalley- thanks for that info. That's pretty much what I expected, but it confirms the depth of the job. I'll look for the write up.
Thanks everyone for the input.
Dave - Tampa
Dec 1, 1999
2,391
The formula results in approx. square feet you need to cover. Most bottom paints will cover about 400 sq ft per gal.
Nov 7, 2012
678
1978 Catalina 30 Wilbur-by-the-Sea
We put on two gallons of Mar Pro Ablative. That said our diver advised us to put on non ablative next haul out as it will last longer.
Dec 1, 1999
2,391
Non-ablative paint, I assume you mean a modified hard epoxy, may last longer, but will be much harder to remove when that inevitable time arrives to remove paint build-up with this paint type. In my case, I use one very thin coat of ablative paint per season. That coat is nearly entirely worn off by the fall haul out time. No dead matrix paint build up to deal with next season. A quick scrub with an abrasive pad, a power wash, and I'm ready to put on another thin coat of ablative next year. I would go with ablative every time.
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Dave,
We just painted the bottom of our C310. Using foam rollers for thin, even coats we got 3 full coats and 3 coats at the waterline only from 2 gallons.
As far as paint, what's the salinaty of your home port? I like the interlux micron 66 for an ablative. But this is a chemical reaction ablative and you need high salinity water or you ruin the paint. I went with Micron CSC because we are doing the ICW and couldn't use the Micron 66. The other consideration is a hard paint. This depends on how often you have it cleaned by a diver. If you tend to have it cleaned then get a hard paint.
On the shaft, with the C310 you can remove the prop, turn the rudder and just barely slide the shaft past. But if you have a solid coupling then your probably at least going to have to replace the coupling if not the shaft too. There are a couple write ups on this in the C310 forum and on my blog.
Good luck,
Jesse
Feb 26, 2011
1,440
Achilles SD-130 Alameda, CA
A high quality, high copper, modified epoxy anti fouling paint, properly applied and maintained, will provide 3+ years of good performance. The OP is in Florida, so he isn't hauling annually to paint.
May 12, 2004
1,505
Ablatives will need to be cleaned regularly if they just sit at the dock. I use mine at least once a week year round and during the summer when the water gets to about 90 degrees I run into four feet of water on low tide get out and walk around knocking any barnacles off. Usually there are no more than a dozen or so and mainly at the waterline. The running gear will have a bit more but are easily scraped off. As a disclaimer, even though we sail in very salty water my marina is located up river where there is a good mix of fresh water. That is sure to have an impact. I haven't cleaned the bottom in six months and just hauled. Less than a dozen barnacles on the hull and a few more on the prop and shaft. That said, IMHO, if you let your boat sit at the dock, go for the hard paint. If you use your boat frequently, ablative is the way to go.
May 12, 2004
1,505
Dave, by the way, Sea Hawk makes an ablative paint specifically for our area. Manufactured in Clearwater. Been using it for years. See post number 2.
Feb 26, 2011
1,440
But know going in that the owner and his management team at Seahawk recently went to prison for cooking the books and deceiving not only the USEPA about the use of tributyl tin in paints they sold in the U.S., but the their boatyard and boat owning customers as well. On top of the prison terms, the company had to pay millions in fines. Now there is some question about slipping product quality standards as numerous Seahawk users complain of product failures.
If this is the kind of company with which you like to do business, knock yourself out. Me- I wouldn't touch these guys with a ten-foot pole.
1,505
Thanks for the info. Seahawk Cukote Blue was applied before I read this. Maybe they've changed the formula or maybe just the name. I'll find out in time. Meanwhile, it has been holding up well.
