Bottom Paint Needed During Long Haul Out?
Oct 20, 2008
26
ODay 23 Niantic, CT
Due to some extended surgery (me!), my O'Day 23 has been hauled out for 2 summers in the boatyard. I keep the topsides, interior, and teakwork..etc in "top condition", but the antifouling blue paint (underbody) is faded and flaking. Should this be repainted, and if so, with what? The boat may need to stay "in dirt" another year!
Thank you for any responses!
Jun 2, 2004
1,952
Oday Day Sailer Wareham, MA
What kind of bottom paint is on hte boat? If it is one of the "Ablative" types, you may be able to just powerwash the boattom to "re-activate" the paint for this season. Alternatively, a light scubbing with a very-fine grit "Scoth-Brite" Pad and water will also work supposedly.
However, if the paint is faded and "Flaking off", then it is time to re-paint with a compatible new paint. I would suggest powerwashing the bottom first (or as above, scrubbing with water and a scotch-brite pad, then once it is dry, Sand the whole bottom with 80 grit paper, wipe it down good, then apply the new paint. I would consult the paint manufacturer's web-sites for best info.
Jun 11, 2004
1,926
Oday 31 Redondo Beach
It sounds like your question is do you need to paint it now when you are still going to keep it on the hard for another year. If that's the question, the answer is no. Clean it up and paint it before re-launching. Not now.
Oct 20, 2008
26
ODay 23 Niantic, CT
Wait for launch next year....I guess so !
Richard,
Thank you. I assume it is ok to leave as is (crummy as that looks !!) over the next winter, and then do the repainting next spring as others above noted! I just did not know if this might cause a long term problem if left "bare". Winters in CT can be severe!
...Sea Drifter
