Bottom Paint for 216
scottg
Feb 20, 2008
2
Hunter 216 pensacola
I need to paint my 216 bottom. At purchase, I was told I had to use a specific paint or I could "melt" the hull. This paint (Interlux Fiberglass Bottomkote ACT) is not longer made. Can't seem to get an answer from Hunter - anyone out there with suggestions? Thanks
Ray T
Jan 24, 2008
224
Hunter 216 West End - Seven Lakes
bottom paint
Try checking with Interlux on their website, they may have something to replace the ACT that will be fine for your boat. I have a 216 also and it will be interesting to see what you come up with. Ray
May 6, 2004
40
Hunter 31 Morehead City, NC
Me too..
I too want to paint the bottom of my H216. I'll see what I can find out also.
ErnieH
Dec 2, 2003
24
Hunter 216 MA
It's the color
Scott, The issue with the bottom paint is the color. The dark color common with most bottom paints causes heat build up that is not good for the ACP hull material of the 216. I used Fiberglass BottomKote ACT (Grey/White) my first three seasons and switched to Micron CSC (Shark White) the past two seasons on my 216. I changed to the Micron CSC because I could haul the boat and launch it the next season without the need to repaint the bottom. I got 2 years out of one bottom painting. /Ernie
scottg
Feb 20, 2008
2
Bottom Paint 216
Hi and thanks for the info. I found a company that could order the Bottomkote so I did but think I may try your suggestion. When talking to Hunter, they never mentioned the heat issue, therefore I ordered the wrong color (they had red, blue and green), no light colors. I'll probably have to eat the cost since special ordered but I have another boat (Cornish Crabber) that I may be able to use it on. Great site, wish I'd found it earlier. Love the 216 design, not so much the company. Sail On!
G
garyg
bottom paint
I have to agree with Mr. Ernie. The MICRON CSC and CSC Extra work exceptionaly well. I put two coats on my 216 3 years ago when I bought it. I used blue ove grey. This will be the boats forth year with out repainting. I am just starting to see some of the grey through the blue. The blue paint did not seem to heat up the hull to much. Dark colored paints on any fiberglass or composite is usually a bad idea. It can cause the hull to heat up enough to the point where the composites suffer some strength loss. Gary
