Steve
I have some places on the bottom where the bottom paint has chipped off. I took a scraper and scraped back to where there is a good hold. I've feathered this back, but because there is several coats of bottom paint there is still a depression of a mm or two. I want to avoid stripping the bottom this year, maybe next year. I want to fill in the depression and fair to the level of the existing bottom paint. What primer/filler should I use? When I was a kid and did autobody work to put my self through college, we would feather the paint back, apply a filler primer, some red putty ( red putty is used to fill scratches ), then sand the red putty, and prime again several coats with filler primer, then sand smooth. This would bring the repaired area up to the level of the surrounding paint. I'm familiar with the concept, put need a suggestion on what filler primer to use under water with bottom paint.Thanks for any help,Steve
