Painting while on trailer
Tip, Saltwater sailors have a greater problem with crud than us fresh water boaters, but the recommendation that you put it off as long as possible makes sense to me.The boat is warranted for 5 yrs against blisters. You'll have to prep the bottom carefully and be able to prove you did it correctly. Talk to Hunter first. Pulling the H260 is easy and a quick power wash once a month takes care of any buildup. I spent $150 on a lightweight 2000psi washer and give the boat a good going over at the same time I wash the bottom. Keeps the boat looking fresh. In between power washing I've found the easiest thing is to just beach the boat, and do a quick walk around with a brush. Makes for a nice afternoon at the beach. Wife watches and feeds me beer...Using this procedure, at the end of the season you'll have a slight waterline stain; an oxalic acid wash takes care of this easily.I think this is one of those things you can slow roll...If you find you are having a hard time staying ahead of the crud, then I'd reconsider. BTW; you'll find lots of discussion on this subject in the archives, but the H260 does not rest on it's keel on the trailer, so adjusting the bunks to get at the bottom is going to be difficult/dangerous. A sling or proper cradle is the way to go. I’d love to get at the boat easier while on the trailer so if you figure out a way, share with us.
