H
Howard
I've just come from my old H-27 for mid winter check. The bottom paint is flaking all over. There are no blisters in the fiberclass. It looks as if moisture has gotten behing the bottom paint and when it freeses it spalls the paint off. I don't think that the bottom was ever stripped before. Under the bottom paint (whihc has always been blue) is a pretty uniform brownish dull paint that looks like it might be the barrier coat? In any case I think I'll need to remove the bottom paint and start fresh. I don't want to sand it or blast it and was thinking of one of the chemical strippers made for bottom work. Several questions:1) Has anyone had good experience with the chemical strippers? Which ones?2) If you use a chemical stripper how warm does it have to be outside. (I in New York )3) Do you use a plastic or paper cover overnight on the stripper?3) After the stripper do you have to put a new barrier coat on? I've never done this before ? Any suggestions from you out ther would be of great help.ThanksHN
