Bottom Cleaning
14
- - smithville
I am going to haul out my boat after 6 months in fresh water lake.What is a good cleaner to use when I scrub the bottom.
Brad Gillenwater
Slimy Grimey
Slimey Grimey does a great job on bottom cleaning a boat.
Feb 10, 2004
4,247
Hunter 40.5 Warwick, RI
I will second that!!
Slimey Grimey is the absolute best I had ever used for brown water line stains and general bottom crud. Literally- spray on and watch the stains disolve away. And bio-degradable too! A friend who keeps his boat in a local lake also agrees.
Jun 10, 2004
14
- - smithville
slimy grimey the winner
looks like slimy grimey is the one I will use thanks Steve and Rich,scrubing in Smithvile Keith.....................................
A
Alan
Why not just ....
....clean it in the water? If you can't do it yourself, just hire the local dive boat to do it for you. Generally runs about $1.00 per foot. A heck of a lot cheeper than a haulout.
Joe
Jun 1, 2004
8,342
any acid based cleanser will do for...
... organic stains like algae and mildew. I prefer liquid toilet bowl cleaner, but Tilex or Slimey Grimy will work also. What worked well for me when I was trailoring was dilute some commercial toilet bowl cleaner ($3.00/quart at Smart & Final) with water 50/50 into a hand-held sprayer and simply squirt it right on the surface then hose off with fresh water. No hard scrubbing please, you don't want scratch that gel-coat. Use a sponge or rag if necessary, but nothing abrasive. For petroleum based stains, like those you get from rubbing the dock, try acetone on a rag, then rinse with fresh water. I want to emphasize, do not hard scrub with anything abrasive or any abrasive cleansers. This is gel-coat, not porcelin.
