Not that big of a deal.
Roger:It is really not that big of a deal going up the stick. If you check the specs on your line, you will see that it is quite adequate to support your weight.I personally like a climbing harness better than the chair, but everyone has an opinion. It is alway a wise idea to go up the stick with a safety line. Regardless of the strength of the line you never know what could go wrong.The key is getting a setup so you can climb the mast yourself or have some strong crew members or harbor apes to crank you up there.
