Boom
119
Beneteau Oceanus 321 Carters Pt.
Looking for a print or description on replacing double reef lines + outhaul line (internal riged boom) on a 1997 Ben 321
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
The reef. line is tied around the boom at the aft end. Each is threaded through its respective block on the sail then back to the sheave at the end of the boom. then the lines are led through the boom to the forward end. Fom there the lines go up through their respective blocks on the sail , then down through the turning blocks at the base of the mast, through the line organizer to the spinlocks at the top of the cabin.
The outhaul lline ties to the clew, is led around the third sheave at the back of the boom, through the boom, around the sheave. at the front of the boom and secures to the cleat at the starboard side of the boom. I have changed mine so that it is also ru back to the cabin top at the cockpit.
This is the way my 323 is rigged at least. Hope this is of some help.
May 20, 2011
34
Beneteau Clipper 323 St Peter Port
My 1st reef line let go at knot by boom and all the way back through the boom. Nightmare to re rig, had to use other reef line to pull through a pilot line this was also a 323.
