www.rigrite.com can probably help you to order one. Ebay is another potential source. There are typically a few mast manufacturer's so figure out what you have and look for similar. Length is important obviously. The foot of your main is probably 10 feet or so. You a need a slightly longer boom in order to allow for tensioning of the main and attachment to the mast. How the boom is set up to attach the main is important too. The boom below may work if you find out the above things I just discussed. Be warned that shipping of a long object may be prohibitive. I just got a quote to ship a car rear differential and it was $700!
May work, but may be too short. The vendor, donsmarine, may be worth contacting as they are a salvage yard. It may be worth calling Hunter too. They may be able to hook you up with a boom. Booms haven't changed much since they made your boat.
