Joseph Washburn
I am in the process of trying to "fix" the boom vang on my 1988 Catalina 22. The problem is that the loop welded to the mast step the one end of the vang is supposed to attach to is bent to the point that you can not connect the vang. So far I have seen two options. One is to have someone like West Marine make a wire lead that would loop through the bent ring and back out that the boom vang would then attach to it. The other would be to purchase a mast hound or boom bail, or whatever they are called, for the vang to attach to. One person I asked was concerned that this would put too much pressure on the mast and perhaps cause it to bend or something. I don't see this as a problem but I am not familiar with the force a boom vang places on the mast. The other option here would be to, rather than attaching this hardware directly to the mast, would be to attach it to the outside of the mast step on either side of the mast. This would make the bolt through the mast the connection point. Any ideas or thoughts would be appreciated.Joseph Washburn"Disciple Ship"C-22 14408
