Solid boom vang
I installed a Garhauer solid boom vang on my 1983 H 33 this spring. My 33 has the Kenyon mast which sits on a large black aluminum pulpit / sheave base. The lower mount originaly supplied, which was intended to go on the mast itself would have ended up at least a foot above the deck, making the angle to the boom too sharp. I had Garhauer make up a lower mount to my design which mounts to a welded in rib on the aluminum mast pulpit and makes the mounting angle acceptable.I've used the vang without incedent all season and aside from superficial surface rust staining it's great, especialy for the price compared to everything else I see out there; $230 as I recall, as opposed to other stuff starting out at about $600,.One note: I saw a 1981 H 33 which had the same pulpit exceept it lacked the rib I used for mounting. I'm sure Garhauer didn't keep a copy of my design, but I think I can find the sketch I sent to them. I know it cam be made up for the pulpit without the rib if that's what you have.If you need it, e-mail me at : samlust@monmouth.com
