A
Aldo
We have sailed our C-22 without a boom vang for long time, and my son sailed on another C-22 this past summer and recommended that we add one soon. I have several questions:1. What should the mechanical advantage be for a C-22 boom vang? I'm guessing 4?2. What line diameter should be used? I'm guessing 1/4 inch. Does the line lead back to the cockpit?3. How far up from the base of the mast, and how far back on the boom does it go? It suppose that the angles should be about 45 degrees. 4. What does the fitting that goes onto the mast at the bottom of the boom vang look like?5. Does the boom vang interfere with the pop top at all? If so, is it removed when not being used, or is there another place that the bottom shackle is snapped, when the pop-top is up?I know that these questions must sound very basic, but I usually used a preventer when we were running, especially if we were cruising. I added a bail to the boom, and then ran a line through one of the jib sheet turning blocks and ran it back to the jib sheet winch that wasn't being used, and pulled the boom down that way. This also prevented accidental jibes.I'm not really intrested in spending the money for a boom-kicker. I have never had any topping lift problems. I simply have a very small line, about 1/8 inch diameter, that goes from the mast head (where the back stay attaches), to the fairlead on the end of the boom, and then onto a little cleat that I have mounted about a foot from the end of the boom. This has work fine for me. (I, of course, use the shackle on the backstay when the sail is furled on the boom). Thanks, Aldo
