John Smolinsky
We finally want to install a Boom Vang but have gotten mixed advice as to how to install the fixed fittings. Installing a bail on the boom seems straightforward and probably the only and best option. It's the mast fitting that is perplexing. One suggestion is a screwed-in pad eye in the sail track,but that involves removing the boom track from the mast in order to slip in the pad eye. Another suggestion was to install a base under the mast which has accommodation for attachment of a boom vang snap shackle- this one is a little impractical mid-season.Another suggestion was a bail on the mast but with some sort of interior "bushing " to prevent squeezing( compressing ) the mast when the bail bolt is tightened. Lastly, we have seen other boast - not Hunters- that have a pad eye with a contoured base screwed directly to the mast. Each option probably has advantages and disdvantages re: strength and ease of installation. What do you think is the best balance? Are there other issues to consider? Thanks in advance for your advice.
