Boom Vang angles
C
clif
I have a Hunter 25.5 What is the best angles on how to install a boom vang? If you went down the mast from the boom connection ie: 30 inches Would you then go from the mast to end boom 30 inches. I have a 4 to 1 boom vang. Thanks Clif
A
Andre K
...Ideally ? -- YES
ideally, you want to have a "square" rig, when you draw the power vectors , a 45 degree angle will give you the most optimal power in both directions of pull
Oct 3, 2006
1,041
Hunter 29.5 Delaware city
Both directions?
(Disclaimer: I'm an engineer trying to go sailor) Scenario 1: The goal is to make the most torque around the gooseneck. X = distance on boom Y = distance on mast F = force by vang inverse tan $ = y/x torque = F (x sin $) with a constanf F, lets say 100 lb. And we'll position the attachment on the mast 30 inches below the gooseneck. On the boom, our limit will be 12" to 40" Result: 1100 in-lb of torque at 12", increasing to 1900 at 24", 2300 at 36", 2400 at 40", and (just for kicks) 2500 at 48". So obviously theres a point where the returns are diminishing, plus we're sideloading our mast section unnecesarily. Each foot beyond the first is half as effective as the last. This assumes the boom is rigid, and a very generic sail. There's more math you could do for a loose-footed or bolt rope sail, etc etc. But heres the general situation. Take it as you wish
Steve O.
Boom angle
I think I read where it's not so much the angle but the distance out from the gooseneck, and I seem to remember that it should be at least 1/3 boom length or more.
C
clif
o.k. so
I have a soft boom vang that I am putting on it. Loose footed mailsail. Boom is 10' long So it looks like it should be 30 inches down the mast from the boom and 40 inches from the mast down the boom 40 inches. I think the load cap is 2500 pounds. Sound right?? Thanks Clif
Oct 3, 2006
1,041
What I'd do..
Is put the vang as low as possible while still being convenient. Then, run the math and pick a point where the curve starts to flatten out, erring closer to the mast. But a 4:3 ratio is probably a great way to go.
