Boom vang and Boom kicker
thaeni
Sep 28, 2008
120
Hunter 33.5 Chicago
I have a 1984 27' Hunter. I replaced the original Main with a loose
footed Main this year. The topping lift has been a real pain slapping
against the sail and getting tangled around the back stay. I want to
replace it with a boom kicker but my boat does not have a boom vang.
Will the kicker work with out a boom vang. All the pictures show it with
a vang.
Thanks
Oct 22, 2008
3,502
- Telstar 28 Buzzards Bay
Why not get a Garhauer rigid vang instead??? Probably not much of a price difference, and having a boom vang helps with sail trim.
RobG
Jun 2, 2004
337
Ericson 28 Noank, Ct
You will need a vang
The Boom Kicker will lift the boom to it's furthest extent, the vang pulls it back down to where you want it. I installed a Boom Kicker three seasons ago and love it. I made the vang myself keeping the cost down.
K
knowitall
RobG called it right. You need a vang with a boomkicker.
You will never regret putting a boomkicker on. They are fantastic. Installed them on my last two boats and what a difference in performance.
Boomkickers are available on this site by the way.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
A cheaper fix is to add a small cleat onto the backstay. Then put a tail of line onto the topping lift (mine is fixed, an slapped just as yours does) and cleat it off there when not in use. My boat has a flag / pennant halyard on the backstay with a block and cleat, and the the cleat is a specific design. This should solve your slapping problem for $10. Regarding the lack of a boom vang, my guess is that yours is just missing. My last boat didn't have one and I had to buy one.
2,288
C30 Event Horizon Port Aransas
Rob G. What did you make your boom kicker out of? And how did you make it?
Dec 2, 1999
15,184
I would have to agree that the Garhaurer solution is a great piece of equipment. They are about $275 and are custom fitted to your mast & boom.
Oct 22, 2008
3,502
BTW, Boom Kicker is a trademarked name for a fiberglass boom support rod that is designed to replace a topping lift. However, because it tends to lift the boom it needs to be used with a vang to keep the main sail shaped properly. Sailing with a boom kicker and no vang is like sailing without easing the topping lift...the sail's leech will be very baggy and the shape will be horrible.
Joe
Jun 1, 2004
8,168
do the math....
.... you will need a boom vang. Since you don't have one it is more economical to purchase the Garhauer rigid boom vang than to purchase(or ever build) a 4 part vang and the boomkicker. It will cost at least a 100 dollars for the vang... two fiddle blocks- one with cam cleat- two snap shackles, attachment hardware and of course around 40 feet of 5/16 line.
The boomkicker is 200 bucks....
The garhauer vang for your boat is 275....
But the best benefit is the improvement in your sailing, you will love it.
2,288
traveller
I have a traveller midship. I think it kind of acts like a vang. Can I add a kicker with out adding an actual vang?
Oct 22, 2008
3,502
Re: traveller
Hermit-
Your sail shape will be lousy on reaches and runs for the most part, since the boom kicker will be forcing the boom up and the leech will twist off.
Jan 2, 2008
547
Hunter 33 (Cherubini design Forked River, Barnegat Bay, NJ
to Hermit Scott
In a word- NO. As soon as you ease the main sheet your boom will lift up, killing shape. It will also stop you from dropping the traveler in heavier wind to ease the helm. I consider going for the Garhauer solid vang to be excelent advice.
RobG
Jun 2, 2004
337
Hermit, I asume you meant to ask
about how I made my vang. The Boom Kicker is a purchased product (I purchased from this site). The vang I made with a new length of 1/4" NE Ropes double braid and some Holt ball bearing blocks i grabbed out the closeout bins at Defender (I live a half hour away from them :)). There was a triple with becket and a triple with becket and cam, perfect! It was a fun splicing project and the total cost was less than $30 with a good snap shackle on the extension. I made it with an extension to get the cam half way up the vang for easier adjustment and so I could shackle it forward on a stanchion base as a preventer. Boom control with this set-up is so much easier than a topping lift IMHO.
Sorry for the late response.
