Boom support
45
Macgregor 25 Morehead City
New question guys. How do you support the boom with no sail up? Sounds dumb, but getting ready to raise mast for first time in yard. Thanks in advance. thanks to everyone on the help with poptop holder.
Gilligan
Smithy
Dec 13, 2010
162
Macgregor 22 Alexandria, VA
Topping lift, or some people have a short wire attached to the aft stay with a clip to hold it up.
Oct 18, 2007
707
Macgregor 26S Lucama, NC
A second halyard, usually lighter than your main halyard, which you can fasten to the end of the boom and support it at whatever height you want. The block is usually at the same height as the block for your main halyard. For mine, I just drilled a hole through my chicken head and mounted a sheave in it. -Paul
Apr 30, 2006
610
Macgregor 26s Kemah, TX
My topping lift is a line tied to the top of the mast and fastened to the end of the boom with a small cleat. This allows you to vary the height of the boom.
Voice of experience: use good line. Cheap line stretches and makes the boom sag.
Sumner
Jan 31, 2009
5,254
What is a topping lift?
As per the other guys I added a sheave also...
...at the top of the mast for the ...
...topping lift. In the next picture you can see what Smithy is ...
....talking about on the backstay that you can also hold the boom up with.
The topping lift is a lot more versatile though. We like it as it allows us to hold the boom not only up, but...
.... also off to one side out of the way. It is also there when you drop the sail and will let the boom swing out of the wind vs. if the boom is attached to the backstay and can't swing much if the wind catches it.
I have the mod here on our site...
http://purplesagetradingpost.com/sumner/macgregor/rigging-3.html
Later I changed the block out for one with two sheaves. The topping lift runs through one and the uphaul for the anchor sail, shown in the picture above, through the other one.
When you get a chance put on a topping lift, you won't regret it and have a good time on that sail,
Sum
Our Endeavour 37
Our MacGregor S Pages
Mac-Venture Links
Jun 3, 2004
1,863
Macgregor 25 So. Cal.
Mine is a little different.
Like the others I mounted a block on the chicken head but the line is also used for the flag.
May 20, 2009
75
mac gregor 22 montreal
You must have a up hall that goes from the end of the boom to the top of the mast then back to the deck to be attached somewhere, ideally in a power clutch
Feb 19, 2010
62
Macgregor 1995 26s Windycrest Sailing Club, Lake Keystone, OK
For a topping lift, I use a single 1/4 in. line tied around the back stay bolt. It is brought down and through the fair lead on a clam cleat, around the end of the boom and then tied off on the bottom bolt hole for the clam cleat. Makes for a quick single hand adjustment, up or down. Believe I got the idea from someone on this site or the other Macgregor site. But it is a cheap, easy topping lift.
Sumner
Jan 31, 2009
5,254
This is what is on the top of my mast. On goes to a shackel, one goes to a turnbuckle with a shackle. Should i take one off and put a block on?
thanks guys
Not real sure what to tell you just seeing ......
.... that picture. The back one is the backstay and I'm guessing that it is the one with the turnbuckle and is used to tension the backstay and put bend in the top of the mast if needed.
If the other one is long and will reach down to the boom then that is probably a topping lift that is non-adjustable and that fastens to the back of the boom, but that is just a guess.
I think before one installs a topping lift they need to consider how they sail the boat and what purpose does the topping lift fulfill for them.
If you are a racer and don't want weight aloft then you might not want one or want one that uses the lightest line and that just comes down from the top of the mast to the back of the boom and holds the boom up while lowering or reefing the main.
If you are a day or weekend sailor mostly then I think a simple line from the mast top down to the boom that is adjustable there has a lot of merit in that it is an easy mod. I'd say the negative to this vs. controlling the topping lift from the mast is that even if the boom is out over the side of the boat you can control its height from the mast. The positive is that I don't mind going to the mast, but some do and would rather pull the boom in and deal with it from within the cockpit.
If you spend or plan on spending a lot of nights out then I would consider having a block at the top of the mast and a cleat down on the bottom of the mast for a topping lift. It is very easy to adjust and also easily allows you to raise the boom higher out of the way. That makes using the cockpit more enjoyable on anchor. Also as TB mentioned it can be used as an uphaul for other things, like the flag or additional lighting or maybe an antenna for WiFi. When Ruth first made our anchor sail at night we held the boom up with the short wire on the backstay that was talked about above and used the topping lift as the uphaul for the anchor sail. We really like the topping lift though for holding the boom up vs. the line on the backstay as it is a lot more versatile, so changed the block out at the top of the mast for a double block for the topping lift and the anchor sail uphaul.
Our Endeavour has a single line coming down that is adjustable at the back of the boom. We don't need to raise the boom out of the way, so what is there now will probably stay there. So there is no 'right' way. Think about how you are going to use the boat and do what is best for you,
Sum
Jun 3, 2004
1,863
I just have a tang so that I can mount most anything up there.
Looks like you have a cable that you use as a back stay and with just a small line you can tie the boom off to one side.
