Normal setting/tensioning of the topping lift.
On a windless day, raise the mainsail including the proper amount of extra 'preload' to the boltrope (about 1" of additional halyard strain for every 11 ft. of sail luff length - this additional pre-load will shape the sail for approx 15kts of wind, less preload for lighter winds). Proper pre-load to the luff boltrope will raise the boom end. Then, put the traveller on the centerline and put in the MAXIMUM amount of strain that you normaly apply to the mainsheet (includes the extra strain necessary to 'hook up the battens to weather' when power-pinching, etc.). **Now, set/cleat the topping lift with this amount of 'stretch' in the sail. Make a mark (wrap of tape) on the topping lift at its cleat/restraint/clutch so you can easily and exactly return to this 'basic' dimension .... or better yet dont ever release this dimension as you can shorten the Topping lift by simply cleating 'over' this basic setting. A too tight topping lift will 'oppose' the mainsheet tension, leaving the mainsail overly 'twisted', etc. If the topping lift is 'too sloppy' for your tastes, leave the above alone / cleated; but, slightly shorten the length of the topping lift until its 'quiet enough' for you, cleating 'over' or 'on top of' the above setting. When done sailing, etc. or you need to 'power-pinch' just release the extra bit that was cleated 'over' on top of the 'basic' setting. Much much better is to use a spring loaded 'rigid' vang ... does the work of the vang AND topping lift, all at the same time .... .
