Boom Kicker on Capri 18
Feb 19, 2008
483
Catalina 320 Tawas Bay Yacht Club
I'm sitting in the boat trying to decipher the installation instructions for the boom kicker, and I have a question.
Wont the bracket at the bottom of the mast make it a super pain in the butt to raise and lower the mast?
There is no clearance at the base of the mast with the mast down. If you add a bracket there, you won't be able to insert the pin.
What am I missing?
Mar 2, 2019
636
Oday 25 Milwaukee
I installed the mast component of the Boomkicker just high enough to clear the mast hinge when I had the mast in lowest position when stepping.
You might have to raise the height of your mast crutch
Feb 19, 2008
483
@Timm R Oday25
That’s kind of what I was thinking.
and my quick math tells me that if I cut 4” off of the rods, it will give me some 2.75” more clearance on the base of the mast.
also, if I leave the gooseneck fitting attached to the rods when I trailer, the part left attached to the boom is skinnier.
Mar 2, 2019
636
Oday 25 Milwaukee
I’m not sure I would cut the rods . This might very well take some of the flexibility out . The pins remove fairly easily for raising and lowering the mast . Any chance you could share a few photos ?
Feb 19, 2008
483
@Timm R Oday25
the instructions say you can cut up to 8” off the rods without effecting the performance. more important is maintaining the approximate 45° angle. I cut 4” off mine, and I think it should work out pretty well.
I can see several ways that this is going to improve sailing, including making reefing and dropping the sail So much easier (the topping lift on the Capri is a pigtail on the backstay).
when I raised the sail in the driveway (with no wind), there were times the sail seemed way too baggy. We’ll see how it works in action - I might need to adjust things.
Thanks for your help!
