Boom kicker, boom vang or both?
bburke
Jul 22, 2015
6
Rebel Spindrift Daysailer 1 Plymouth, MA
I've always only used a boom vang, but I'm putting a 17' daysailer back together and wondering - if a boom kicker will act as a vang and a topping lift - why bother with a boom vang?
Nov 8, 2010
11,386
A boom kicker only acts like part of a RIGID vang system that pushes/holds the boom UP. You need a soft vang to work with it to hold the boom DOWN.
Nov 9, 2012
2,500
Oday 192 Lake Nockamixon
Yes, you definitely need both.
The Boomkicker is useful for two things: 1) Keeps the boom from falling into the cockpit when you douse the main 2) Supports the boom in light airs when the weight of the boom would normally pull the leech too tight, right when you want a more open leech for more twist.
As the wind comes up, you need less twist in the main, so a tighter leech, and that's when the vang is needed to pull the boom down against the lifting force of the Boomkicker.
Remember that if you get the smallest Boomkicker, that has a webbing cradle to hold the boom, if you push down on it too far, the Boomkicker flexes and pops out from under the boom. Very startling when it happens, especially if you happened to be leaning on the boom a bit too much, and you're suddenly WAY off balance... Don't ask me how I know :D:D:D
