Admiral,
Using your topping lift, here's alittle trick I use. Some of my boat pals liked this & now use it.
At the dock after sailing & flaking the main, before I put the mainsail cover on, I adjust the TL to raise the boom up 6-8" higher than straight horizontal.
The reason I do this is for hoisting the sail next time out. With the raised boom, this takes out the boom weight pull on the leach when hoisting. Next time out sailing look at the boom position on other sailboats. With their sails up, if the boom is lower than horizontal, you will see stretch lines in the sail that follow the angle of the leach. What this does is stretch the sail & shorten life & performance. When raising the main, you want NO boom weight pulling against your sail pal. Once it's up, then slacken the TL & you will have an evin pull along the foot.
Another advantage of a raised boom @ dock is if using the proper flaking style for wrapping the main, rain water that gets thru to you sail will have a chance to drain off rather than sit puddled inside & collect mildew.
CR
