Yeah, its designed that way
Dave,
The h23 was designed, and the main is cut, for the boom to hang below level. My experience (original owner of a '86 boat) is that if I'm sitting in the forward half of the cockpit, the boom will miss me, but aft of that I need to duck. FYI, I'm 6' tall. The prior postings are correct, you would have to recut your main and suffer the lost power if you want it to hang level under sail.
You do have a topping lift, assuming you installed everything. There is a line(provided with the boat)running from a pin at the masthead to the aft end of the boom and then through the boom to exit just under the gooseneck fitting. Pulling the line raises the boom, letting it out lowers it. Getting under way, I let it out once the sail is raised so that it does not affect the position of the boom. Similarly, I use it to raise the boom before dropping the main. In very light air, I use it to raise the boom just enough to take of the weight of the boom off the sail, improving my sail shape.
When we're not sailing, I sometimes use the topping lift to raise the boom to make more headroom. Like Brian, I cannot open the seahood hatch all the way without raising the boom. No big deal because I don't normally want it open anyway - the slider provides plenty of room.
Enjoy your boat, it provides good performance and room for a small family in a reasonably trailerable package.
Jim Kolstoe, h23 Kara's Boo
