Randall
We sail in south Texas, so we need SHADE! I want to install a fixed bimini with enough standing headroom for average height folks (5'9"). The previous owner had the boom set low on the mast track-- about 8" too low to clear a custom bimini. However, I can loosen the gooseneck and hoist the main all the way up & gain most, if not all, of the boom clearance I need. What is the most efficient boom height? Will maximum hoist raise the center of effort too high and hurt performance, or is it designed to be hauled all the way up? The H25 pictured on this site appears to have the boom at max hoist, & looks to have plenty of clearance for a bimini. I'm fixin' to order a new Doyle loose-foot main with two full length upper battens. If I still need more bimini clearance, how much harm would I do to performance by having the main cut 4-6" shorter? Seems to me that a slightly shorter loose-foot would perform as well as a standard height bolt-foot, unless the higher center of effort induces too much heel. What's the solution? Randall
