Hi Gang, I seem to be having some difficulty in pulling the clew of
the mainsail out at the end of the boom and making adjustments. The
line that pulls the sail out is attached and goes from the groumet
around the pin to a side check pulley around another pulley and then
to a cam cleat. Seems I don't have enough force or I have it rigged
incorectly. What is the usual setup to pull the mailsail tight? Am I
missing a set of pulleys somewhere? Anyone explain the correct
routing and gear to make this adjustment easy? Have never seen
another Vega rigged or any thing in the Vega Manual to show the
proper way to have it done. Appreciate any help on this. Thanks Walt.
