What is bonding? How do you know if you boat is properly Bonded. I have a 1979 Hunter30. I bought it used 20 year ago.
The article that Bill is talking about is a good one and is still valid. There is only one ground point on an ac system and that is at its point of service where the neutral and ground rod or plate are tied together, after this point it is a bond. If you have an isolation transformer, then your ground is at the secondary of that because that is where the neutral and the ground will be tied together. They should never be tied together afterwards. bonding any 2 points of metal exposed to the water and that are any distance apart will promote galvanic action as electricity flows in a circuit only. You create a circuit in the water when you tie those 2 points together with a bond. They literally become a battery and if they are 2 different metals, then the less proud will disappear and faster than you might think. If they are isolated in fiberglass, no circuit, no problem. You have to perform du diligence in ensuring that these isolated points are not tied to the electrical system in any way so they do not become a hazard.What is bonding? How do you know if you boat is properly Bonded. I have a 1979 Hunter30. I bought it used 20 year ago.
