Dichotomy Dictates Delemma
You are both right.Franklin, I have been following your posts on this subject when I could, and you have done mucho work following these little gimlin-devils all through yer bilge etc.They use 'silver nitrate' and long leads to test for a ground fault, and bonding is tested but there is a huge controversy foing on by some world reknown experts on this exact subject on another forum, and the consensus, well there is no real consuesus except that the most knowledgable fellow I know says DO NOT bond through-hull fittings!There is one that all agree on though: if you change your through-hulls to Marlon you will have no further trouble with electrolysis nor the freezing of the ball-valve handle.
