Maine Sail - whats your take on this? Should a boats bonding system be completely seperate from any DC ground? The only way to do this is to not connect DC negative to the engine block, no?
If lightning suppression is taken out of it (mast, stays, etc to keel), and bronze thru-hulls are bonded together, the system would need to be bonded to the prop. The rub is if ya do that, you're now bonded to DC negative via the engine block.
