Hi.
The bolt that holds the cover/gate on the mainsail track above the
gooseneck that allows mainsail slides/slugs to be removed has worked loose.
I'm not clear whether the bolt was originally screwed into a captive nut
inside the mast or whether it was simply screwed into a hole in the
aluminium mast.
Perhaps the first as I have had the mast up & down a few times and could
have shaken something loose when transporting it.
I've temporarily used some epoxy to secure the bolt (and the cover) in
place.
Any suggestions for a better long term solution?
Maybe some kind of expanding bolt or one of those patent wallplug for
thin walls that expand inside the hole and grip from the inside when
bolt is tightened?
Thanks
John V1447 Breakaway
aluminium mast.
place.
bolt is tightened?
Thanks
