A
Alan Liebnick
This past summmer I've noticed that when my Yanmar is running at 1100-1500RPM the boatand aft stays would vibrate tremendously. There was a constant knocking below the boa. The sound was eliminated by either raising or lowering the RPM. The yard hauled the boat and said a the rudder shaft bearing needed to be replaced. The sound was coming from the rudder post I guess. The problem was solved initially however it has returned. This time at 2000 rpm. Also it does not happen all the time. If the seas are rough and we are motoring it does not occur. I am confused as to what it causing this and what to do. When the vibration occurs it really can be LOUD! My wife jokingly says our boat runs at 3 speeds 1. slow 2. medium and 3. who needs a man.
