Both of our boats came with those long thin plastic sleeves that snap onto your shroud stays to help reduce jib sheet abrasion. Of course around here they gunk up with green stuff and grime. So, this racer gave me a tip the other day. I've made them and need to get to the boat to see how they work. Our boat has two sizes of turn-buckles. The inch and a quarter and inch and a half inside diameter white PVC pipe from Home Depot were large enough to slide over our two shroud stay turn-buckles. Using starboard cutting boards purchased from our local thrift store I cut washers to match the outside diameter of the pipe with holes drilled to slide over the turn-buckle bolts. The five foot long pipes will cover the shroud stays to protect our sheets from abrasion as well as allow rain water to flow through.His idea seemed to make good sense to me. I'll let you know how the trial turn out goes.Terry
