W
		Woody Morison
Yesterday I looked at a 1978 Catalina 25. I noticed the following and  would appreciate an opinion.1. The very bottom portion of the mast support has the laminate peeling from it and I caould stick my pocket knife in the side of it at least 1/4".2.The cock pit floor is mushy the fiberglass is oxidiced and coverd with tiny cracks. Not long deep ones but more like a spider web. The ply wood undereath is soft, howevr the glass work under that "ceiling of aft double birth" appears to be flawless. The current owner sugested using "git-rot"to repair. I think this might be a temporaray solution that wiil cause bigger problems later.3. The back adjustable mainstay is missing it has been replace with a non adjustable  cable connected directly to the starboard side. I have not found the parts to put it back orriginal. The boat seemed to favor sailing with the port side into the wind.4. The rudder has been damaged and is now lamminated between a 1/2 piece of alluminum on each side, Strong but not very sleek.
