Boat Name to be remove
Patrick
I'm trying to apply a new name graphic to the stern of my 1984 Hunter 34. The problem is that the existing name was painted on and probably touched up yearly. I have tried various solvents and have had no success in removing the paint. Is gentle sanding the answer or will this leave patchy colour differences across the stern. Maybe there is a miracle solvent out there. Please advise.
Dec 2, 1999
15,184
It is a miracle!
Just apply OVEN OFF oven cleaner. The warmer the temps the better. Just spray it on and let it set for 5-10 mins. Then using a deck brush you can scrub it off. It may take two-three applications depending on the build up. Rinse with water between applications. When you think that the oven off is not going to remove any more paint you can take some acetone on a rag (DO NOT APPLY DIRECTLY TO THE GELCOAT) and clean up the remaining spots. They you can use some rubbing compound or some good wax/polish to clean it up. If you are not in a hurry, you should leave the area exposed to the sun to bleach out the area as much as possible. The area where the old paint was tends to be yellowish. The sun will help to equalize the color. This method is recommended by most of the sign painters.
red coles
PBJ
PBJ, is "peanut bitter,and jelly", but just give me chunky PB by itself. red
Ron
Yes, Oven Cleaner
Make sure you wear gloves. If you are working at the dock, use a method to contain the spills. Our friendly water creatures will love you...
