Boat Lift for Capri 26 - HELP
L
Lynda Edwards
I'm desperate. My Capri 26 is nearly on the mud. The lake I live on is now being used for it's designed purpose, a water source for the city of Houston. The level of the lake has dropped so low that I now have only 1.5ft under my wing keel. Future wide swings in depth are expected. The boat lift that was just a future luxury is now a present urgent need. No one I talked to has a clue what the lift should look like. They build mostly power boat and jet ski lifts. Does anyone out there have a workable design for a boat lift for my lady? Please rush your ideas as the level is dropping daily and there's no rain in sight. I can be reached at 409-856-8659 fax 409-856-3768 email sailor26@sprynet.com
E
Erik
Boat lift info
Try posting your question on The Trailer Sailor website's Messageboard. Many knowledgeable sailors from across the country frequent the board and will probably be able to provide good advice. Access it at <www.trailersailor.com> Click on the 'Messageboard' in the main menu.
A
A. Danielson
Boat lift?
I have a Capri 26 which I haul out every winter. The marina uses a crane with a metal rack, from which is suspended two straps. Each year, prior to hauling, I supply the marina operator with a diagram of the boat so that he knows where to position the straps. I don't know if this information is of any use to you, but if it helps I can send you a photograph of the crane & rack via e-mail. You can contact me at ADanielson@erols.com. best of luck!
