Hi Stu
Had a Catalina 26 for the last 5 yrs with a tiller and never felt the prop walk while going forward ! Could it be that you feel it more with a wheel? Or the 3 blades prop accentuates the effect . While backing up , I am used to it !
Thanks anyway
All single screw boats have prop walk to some degree, and the closer the rudder is to the prop, the more pronounced it can be..
Powerboats counteract the force with trim tabs on the rudder or outdrive, but if we did that on our sailboats, it would pull the opposite direction when we were under sail.
Some boats with transom hung rudders can experiance very little prop walk going forward.
If you believe your problem is a bit extreme, check for any fouling of the rudder, such as a line around the rudder shaft..
Another issue that is common and often mistaken for abnormal pull to the left/right, is a dry/stiff turning rudder... with the help of the "prop walk" and the vibration of the engine, the wheel will turn fairly easy in one direction, but when turning the other way, the force needed must overcome the prop walk and the slight binding created due to the opposing forces on the dry shaft... making it seem like its pulling worse than it actually is.
so as the boat yaws as it moves thru the water, fighting the wheel becomes a burden that takes all the fun out of it...
Find a way to lubricate the rudder shaft bushings...
