I suggest that you take agarden hose up and submerge the end in the pond and turn the spigot on. when you get a good flow in shut the watr off and disconnect the hose from the spigot and lay the end on the ground a siphon will take care of the rest. go enjoy a beer or two. The boat is on the hard? Yes? If it is in the water get a 115 volt sump pump and set that up.
I had the cockpit drain line crack and drained all the rain water back into the boat. The boat was on the hard at the time. I got a cheap sump pump from Ace hardware. I think I paid about $45.00. I pumped the boat as far as I could with the sump pump then used a hand pump to get the reset of it out.
