Sumner,
My intent was not to offend or to pick apart your work. If I did offend I apologize.
Like I said, this was my 2 cents. I too have built many things including 2 houses and countless other projects in my 60 years of "fixing things".
My issue was not so much with the 2x4's in compression, but more with the scantling of the materials to resist any twisting forces.
I did look at your other photos before posting, and in looking again, I realized your supports were for getting the boat off the trailer and not for working under the boat.
For lifting, I built a similar set-up, but as I was spanning 20', I made beams from 3 , 2x12's, with plywood glued and screwed between each board, then lag bolted together. When I lifted the boat I had maybe 1/8" deflection in the beam.
The chain falls are on a aluminum 14" I-beam with 3/4' thick webs that set on the cross beams so I can move the chainfalls to space the straps where I like.
I found a reasonable deal on boat stands and used them for working under the boat.
For working inside, I made a different set of stands that fit the hull shape, for the boat to sit close to the ground.
Again, sorry if I offended, but like I said, just my 2 cents. Maybe I tend to overbuild, but then again, better safe[er] than sorry.
By the way, I recently, [about a month ago] read your entire blog as I'm heading to the Keys for 2 weeks next winter, and enjoyed it very much.
robj
